sound processors
fatboyracing
ok I need advice I want to keep my factory radio navagation xm ect.
I cant really afford the 360.2, so its between the cleansweep and the mtx re-q5.
the advantage I see with the mtx is that there is front rear and sub out put.
and the clean sweep just has front and rear output.
I am going to run a 4 ch and a mono on the subs.
I think the cleansweep is designed as a "pass thorough" just to unequalize the factory deck. Perhaps you should look at a good LOC and then design a system as normal ..... unless you're factory deck has a preset EQ curve built into the output.
fatboyracing
fatboyracing
Owensboro KY
PaulD
