Sound Deadening
  • 4
tooshort_128
I'm still putting together the pieces to my system but am thinking about getting the jump on my acoustic treatments. I've been checking out GTMat Quadro which has CCF built into it. I was thinking of covering about 75% of the outer door skin with it, sealing the one large opening in the door with mdf or abs plastic, then covering about 75% of the inner door skin, and putting a layer of MLV on top of it. I plan on putting more on the back wall (F-150), but wonder if doing the rear doors would really make a difference? Does this sound like a solid plan so far?
It's a new truck with a pretty quiet cab as it is. Maybe I'll try it without deadening the back doors and go from there. I could address that later down the road if I don't have enough left over.
I disagree with most. That **** is very sticky and only needs a quick wipe with isopropyl, assuming you aren't trying to adhere it to carpet or a...
33
I’m very far from a car audio expert; one only has to see my recent posts around here to know that. I am, however, pretty knowledgeable on cars...
22
1) That is correct. I bought mine from Amazon. Those were the actual links I used to purchase it. If you're budget conscious I'm sure you could...
Just got off the phone with Matt, that box isnt going to work, but ill put this out there..... https://www.soundoffaudio.com/ Anyone in south...
23
900
tooshort_128
tooshort_128
Sterling, VA
tooshort_128
    May 18, 2024
    May 16, 2024
