sound dampining
ross
i would like to know if i can use peel and seal in place of dynamat if i just use about 3 r 4 layers . dynamat is impossible to find over here much less any other similar materials like fatmat and the like so please tell if this can work.thanks 4 any reply
You can, but I think the heat tolerance for peal and seal is low, and since you're in the bahamas, I bet you car can get over the max temp for it. I heard its something like 135 degrees and it will start melting. Have someone else put input before you do anything.
If you live in an area where it doesnt get hot very often then it might be very hard to find peel and seal...if you cant find peel and seal just order edead from ED. It cost just a little more but not nearly expensive as dynamat. Edead should also be able to handle higher temps also.
ross
ross
bahamas
supa_c
