somewhat crazy install...
DAATH
dual focal k2p mids per door with morel piccolo's in the a-pillar? i'm looking for alot midbass with loud clean output. i listen to mostly metal. i will be running 3 idmax 12's sealed with this application. anyother suggestion or thoughts on the k2p's would greatly be appreciated.
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
They wanna know what exactly are you asking? An one person gives you his opinion an you reject it an basically say its a shitty opinion. Sounds like to me that you already have your mind set with the focals since you talked with jeff smith (whoever the fvck that is)
The problem with this is you do not provide enough information you list drivers but not the power you plan to run to them...
this makes a huge difference in the setup and driver choices.
Something an MECP CERTIFIED installer would have already known.
x2 plus didn't you say you couldn't stand jeff smith?
it was a joke about jeff smith... he's one of the best tuners i know. other than doug potter //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
i think i have it figured out. were gonna run dual mlk165 drivers per door paired up with id ultras. gonna make it simple.
for subs my problem is amp size. i wanna go with the hertz h2 for my front stage but the amp is freaking huge! that amp puts 600 X 2 @ 2ohm. i think larry with elettromedia said the h2 is 9" wide 21" long
Yeah, you should see a Rockford 1500.4 BD. The amp is 36" long and at 1ohm (yes it is a rull range amp that is 1ohm stable) puts out almost 500x4
wow!!!! i saw that amp... i thought it was just a mono D class amp
DAATH
DAATH
atlanta
DAATH
