Someone please help! (pics)
You can get monster cable 1/0 for less than than that four gauge costs at your local shop, fyi
It would be less than 30$? I saw a 4 gauge amp kit on sonic for $19. Company is install bay. Im sure its cheap wire but would probably be fine for just 100-200rms right?
But if that 0 gauge isnt too much more ill probably get it, hook it up to my quart amp. Then use the 4 gauge wiring from that on my kicker.
But theres this big silver bolt that hold my seatbelt to the body of the car. Would that be a good ground? Would meter it my DMM suddenly wont turn on.. I can upload a pic if needed
It would be less than 30$? I saw a 4 gauge amp kit on sonic for $19. Company is install bay. Im sure its cheap wire but would probably be fine for just 100-200rms right?But if that 0 gauge isnt too much more ill probably get it, hook it up to my quart amp. Then use the 4 gauge wiring from that on my kicker.
You can run both amps off the 0 GA. And your amp is 200x2...
Will be swapping rca's out tomoro. SO heres the new thing it likes to do. At HU volume 35/50 or slightly above that, the music completely cuts out after a few seconds and comes back on when i turn the HU volume down. Gota be the RCA's or HU
Is the amp going into protect the new symptom could be that your going under voltage from bad wiring/ground fault or your speakers are somehow at too low of an impedance load causing the amp to go into protect.
Yup! just tested it. Played at volume 35/50 and it went into protect in a matter of 10 seconds. Which is strange because i was playing it just as loud as i am now with the gain even higher for a couple days and this didnt happen. UUGHH so aggravating.
Just got an idea. I could unhook my speaker wires connected to the amp. THen turn volume back up to 35/50 and see if it protects still. If it does then that would eliminate a low ohm load produced by the speakers.
stay_high
stay_high
Florida
stay_high
