traksta15
I love lamp.
ok, so i got my box in (1 cu ft tuned to 40hz, downfiring console box) and finally got everything installed (dd 1508 (single 4 ohm) hooked up to an orion 1200d, seeing about 425 rms) the problems are this:
on certain songs when I turn it up past a certain level, the sub makes a weird noise and its something you can def hear over the music, like the sub is bottoming out. I tried playing with my h/u and amp settings and this is what I have so far:
h/u (jensen 9512)
sub cutoff is it 80 (out of possible 50hz/80/hz/100hz and 200hz)
everything else is at 0, no bass boost or anything turned up
amp (orion 1200d @ 4 ohms)
low pass filter is at 250 (maxed out, it's the only thing that makes it sound anything like remotely good).
my high pass filter is off
gain is about 1/2 ways up
phase is at 180 (switched to 0 and nothing changed)
slope is at 12 out of possible off/12/24 (changed this and nothing changes)
now on certain songs, it sounds decent but i never get that "satisfying bass", there are little or no lows on lil waynes "lollipop" but his "a milli" hits pretty good, i know it's not a defective sub, and the box is not the problem either, so im pretty sure i have some of my settings off....thanks again guys, any help is greatly appreciated.
h/u (jensen 9512)
