Someone Help me please.
Flashardy
Ok I got my Amp and Amp kit (wires)
I hooked up the Ground to the amp to the body of the car making sure there was a connection.
Then I did the fuse to the battery, then connected the 12V to the amp from the battery.
Connected the RCAS etc.
Well anyways the amp is not working. The light is not on or nothing.
I have a bulb tester and tested to see if it was hot and it is.
But no light is on nor it wont work.
Also I have a Pioneer Premier Deck, Model DEH P680MP
Where do I Hook up the RCAs?
The AMP is a 2 CH 100 Kicker.
I am hooking up 4 speakers to it for the moment.
Thanks CLH
no no...
All decks come with a wiring harness... Wiring harness has all the wires for all your speakers, power, illumination, etc... One of the wires on the wiring harness is solid blue, and most have a tag on it that says "remote turn on". You need to connect thise wire to your amp. On your amp, there should be three inserts: 1.) power 2.) ground, and the third one is: Remote turn on...
Thanks Guys for all your HELP!
Jeeper07 When you said skinny wire, I was thinking and thinking. When I 1st opened the Pack...I thought it was a Speaker wire. Well I guess it was not.
So I spent the last 1hr hooking that up and putting the final touches on it.
It works really nice for 60bucks.
Well I look forward for more help in the future!
Thanks Again for all the help.
no no...
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif a solid blue on most every deck is the power antenna turn on.
its the blue/white stripe that your lookin for..
Flashardy
Flashardy
Oregon City
Flashardy
