some noob questions.
metalheadZZ
i have 2 re se 12s in a sealed box wired at 1 ohm to a hifonics brutus 1605. how do i know how much power i am giving them.
also if the subs are 600w rms do i need to be giving 1200w off the amp since there are 2 speakers or if i put 600w off it will they both get 600.
also another dumb question but since there is only 1 pos and 1 neg speaker wire comming out the box does it matter what terminals i hook them up to on the back of the amp since there is a place for 2 of each on the back of the amp.
any help would be apreciated.
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
try drawing a diagram to give every one a little better idea of how you have it wired up
Set your gains correctly using the tutorial in the amplifier section. This way you can set your amp to output 1200w.
For two 600w RMS subs, you'll need an amp that does 1200w.
It doesn't matter which terminals you use on the amp, because each on leads to the same place. Just make sure you use one + and one - //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
metalheadZZ
metalheadZZ
Houston, TX
metalheadZZ
vegang
vegang
