Solox box help
How big is the port area?
L port (4in wide 16x14) curf in front
---------- Post added at 07:10 AM ---------- Previous post was at 07:09 AM ----------
I ran my solo x on a kicker kx2500 in 4.75mor^3 an it was doing pretty well. What are you wanting out of it??
more SPL
If you want more SPL, you need more port area. I'm running mine (daily) in 5.25 each after displacement (roughly what you are) and I have 4x24 slot ports on each one. 18in deep. Try 5x16 18in deep and don't do an L. You should see impressive gains getting that L out of your port and increases port opening. You might want to tune a bit higher too, Xs love 34-36. You are also running a ton of power for 5.5 cu. tuned to 32. It may be quiet because it isn't cooling properly. I tried running 5k to mine and they hated it. Get much louder on 3k for the both.
With that kind of power, just rebuild for 4.5cu after displacement and for and do a 4x20 slot port, depth will be per the tuning you want to get to. Problem solved.
Have no idea how to design a box so will need help doing this can build it no problem
Be easier to build a new one
Do that then. Also pay attention to box aiming and position in your car. Just the physical layout and direction you aim sub and port can be a huge difference (like 5 or 6 db)
Post pics of your trunk and current setup you may get some good ideas from guys with experience with whatever you're driving.
Thanks its in a 96 blazer so was thinking sub up port back
But will need a design I have 38wx24dx20h
To work with
Thanks its in a 96 blazer so was thinking sub up port backBut will need a design I have 38wx24dx20h
To work with
26 L x 20 D x 17.5 H
Double face the top, slot port on back 4 H x 20 W x ? D per your tuning. Use winisd w/ those dimensions to get port depth for 34-36hz tuning. I would but don't have it at work.
I don't have that program if you get at me when you get home that would be great
nate56
nate56
colorado
Moble Enclosurs
vegang
vegang
