solid 2400rms at .5 under $300?
We'll good thing it's only ur opinion because facts are facts. Hifonics svcks. And the ph4000 will do .5ohm and 2k clean all day.
Just my own personal experience. Yours and mine just vary. Setup who knows how many maxxsonics powered setups at under 1 ohm. A quart onyx 2k(similar to a brz2k) that i personally ran should have died a few times over and worked fine for a over year at .5. Three separate times I've put in those little ab's and they sounded terribly weak for what they're supposed to be. And the one I put in at .5 kept shutting down on me. If you'd had my experiences with em maybe you'd feel the same.
Sorry if i sound bit biased. My last vfl 4480.1 hybrid left a particularly sour taste and their board layouts are similar with the ph.
Also similar to apsm's but I'll be the first to admit board layout isn't everything.
Blew quickly?
Never made any power, direct swaps with a 1600 brutus and the brutus outperformed in every case. only thing changed was the amp, only way it actually played any bass was if the gain was extremely high with bass boost on. If the gain was just high without bass boost, door speaker's midbass sounded louder. This was bought new. While the brutus reached input voltage on the dmm with 50% gain, the hybrid didnt reach ac voltage for 2000 watts at all. Highest was 36 volts ac with everything maxed.
Might have been bad off the production line, but others have experienced the same as me. I RMA'd that amp and traded the new one in with vertex audio.
ThatChevyGuy
sue me, its a ford.
ThatChevyGuy
Georgia
BassAndBeer
