- Thread Starter
- #16
https://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias%3Daps&field-keywords=indent+crimping+tool&rh=i%3Aaps%2Ck%3Aindent+crimping+toolI always solder for probably 12 gauge and smaller since it can easily be done with a soldering iron. I tried soldering 4ga CCA once and I couldn't get the wire hot enough with my iron or gun (maybe it would've worked with copper). I tried a propane torch and that got it hot enough, but it was a charred mess. For large wires I used a dead blow hammer and an indent crimping tool:
My father had a 300W soldering iron, it was a monster. I used it sometimes, but usually the soldering gun for small electronic work. It would have soldered that 4AWG easily!
As far as electrical resistance goes, I'd imagine it'd be negligible if either way was done correctly - at least initially. For small wires I prefer soldering over anything else because I know the connection won't come undone or oxidize easily, so I don't have to redo it down the road. For the large gauge wires soldering would probably be ever so slightly better, but unless you're going for a record and trying for any tiny increase possible I don't think it's worth it. Crimped correctly the wire would probably support my weight; it's not coming undone easily.
