I never understood this. If you look at subwoofers, lower ohm rating meant lower QTS and QES, which means better cone control and sound quality.but in all honesty the lower the ohm rating usually the sh1ttier the sound...
I never understood this. If you look at subwoofers' date=' lower ohm rating meant lower QTS and QES, which means better cone control and sound quality.[/quote']
The QES of a driver is about is about the least important thing I can think of when it comes to SQ, unless we are talking about matching the QTS of the driver and using the system to compensate, that is important. However to say a high Q driver inherently sounds worse than a low Q driver is incorrect.
Also why changing just the impedance of a driver will have an effect on the speakers QES, BL still dominates the issue. If you want a speaker with a low Q, use a strong motor, making the driver .25ohm isn't nearly as effective and very impractical for many reasons. Shoot the lowest Q drivers you'll likely find are mostly pro audio speakers which are almost all 8 or 16ohm.
That is a good question. I have not seen or herd any real complaints so far.anyone know how a stock hu can Handel these 2ohm speakers?
THD goes up but overall remains very low.most all of the specs, as far as thd, thd+n, damping factor, head room, channel separation and so on are usually taken at 4 ohms. Now if you have an amp(just an example) that is 500 w rms @ 4 ohms with .08%thd+n and has 1.5db of head room and a damping factor or ...200..well now load that amp at 2
ohms. For the most part, the thd will have a "big" jump, the head room will nearly be cut in half...if not more and you can loose up to half of your damping factor as well.
Plus the efficiency of the amp will go down a good bit as well. (not all amps will have the same effects as bad as others will...class a/b amps seem to do well vs others but still lose out some into lower loads..)
