Slamology, 3x DBDrag/Truck Show, Sep 2-3 Indianapolis!
TypeRBass
Walls are for wussies
I think i just may hit this up this year...sounds like it'll be a big show and a good time all in all. I know its a bit early, but anyone else gonna hit this up? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
yea.. i think i may go... depends on the hours i have to work. I've never been to a comp before.. and im like 20 minutes south of indy... any idea where its taking place at?
I know it was fat last year, didnt make it into the show, but it was alot of people.
edit: I believe its at the state fair grounds.
I'll be there. It was a pretty good time last year. I would love to hear your setup TypeRbass if you make it there //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
front doors are subs...fyi Go with AudioControl 6x9 components up front and coaxials in the rear. You will be impressed with just changing to that.
411
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
Then I would get the dual 4 ohm subwoofers and wire it to 1 ohm like in the link below. Those subwoofers are 500 watts rms so running them at 1...
ok i get it dodge ram and full strip inside for second skin . power is run down drivers side and speaker wire is run down passanger side thank you
TypeRBass
TypeRBass
Tinley Park, IL
ContourSPL
    May 16, 2024
    May 16, 2024
