skar vvx10-v3 1.75@32hz
He is correct... I already modeled it and saw big-time compression if you ACTUALLY put 600 watts to it... I'm out at this point... I'm still learning and I've already given too much "advice"...
Barnicles.. Well im not married to the box dimensions, ill have to reach out to someone for some dimensions. Back to google i go!
[quote name='pathfinderone']Barnicles.. Well im not married to the box dimensions, ill have to reach out to someone for some dimensions. Back to google i go![/QUOTE]
@Buck can you help this guy out?
just try 25 sq in port (so box would need to be tad bigger over all, same cf ad) make sure u subtract sub disp. too should be good
Alright i think i have something solid.. I measured my allowable width base on wanting to make a double enclosure. Here are my specs
Width 21
Height 15
Depth 20
Displacements .15
Wood width .75
Port width 2
Port height 13.5
Port length 30
Leaves a net volume of 1.79 and tuned to 34hz which i feel like is close enough.. Ill mess with the numbers a bit more and see what i get but i havent been near my own computer in a while so i cant mess around with winlsd.. These numbers seem to look a little better though. Any input?
pathfinderone
pathfinderone
bellingham, WA
iLL Ridge
