Size of box?
check teh kicker website, if you lazy i m lazy too:nono:
it would prob be somewhere around 1cu feet for each chamber
Says 1 - 4.6 cu ft per sub. But how do i tell what i need. Whats the size matter. I can put 2 12" subs behind seat. sould i go with 2 or what. Any sub recomendations?
Originally posted by MaDroX420 Says 1 - 4.6 cu ft per sub. But how do i tell what i need. Whats the size matter. I can put 2 12" subs behind seat. sould i go with 2 or what. Any sub recomendations?
Did you get the subs yet? If not, how much $$$ you got to work with, and you need an amp too, right?
Also, what are the dimensions in your truck that you have to work with for a box?
for subs, I suggest Adire Audio Shiva's, http://www.adireaudio.com, ED K series, http://www.edesignaudio.com...both subs can perform excellent in small enclosures.
dunno i have right now about 400-600 us dollars. id have to go measure it buts its a single cab f150 98. thinking either jbl 600 or 1200 depending on subs
Originally posted by MaDroX420 dunno i have right now about 400-600 us dollars. id have to go measure it buts its a single cab f150 98. thinking either jbl 600 or 1200 depending on subs
Get the 1200.1 and 2 12" ED K's:D
Originally posted by MaDroX420 kinda wanted to go with kicker tho. whats the diffrence between the sizes of the box. Sound wize?
A larger sealed box will allow for deeper bass...but you don't want to go too large...the K's will outperform the Kickers all day...
Originally posted by MaDroX420 yea but ive heard Comp vrs before and i taught they sounded good enought to go in my daily driver is all
Well, if you heard em and like em, go for it. I'd give em at least 1.5 cu ft per sub.
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
40-85l is about the size range most high powered 12" woofers will want for a box. You should use manufacturer suggested box specs unless someone...
I would like to a bandpass box wherein the subs are facing each other and each have their own sealed enclosure with the center section being the...
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
MaDroX420
MaDroX420
Albany, La
MaDroX420
    May 16, 2024
    May 16, 2024
