Had to do the same. Imagine a 75 lb. box then add 100 pounds worth of subs. ..that's a lot of weight.Not anymore... the subs can be mounted after you get the box in the car... subs up/port back remember?..
Maybe 1-1.25"What is the appropriate dowel thickness?
Sent from my MHA-L09 using Tapatalk
How many kilos do each of your Bonecrushers weigh?.. the box without the subs will be considerably lighter... and if you use Birch it'll actually be LIGHT... it's only single 3/4" thick material throughout...Hmmmm[emoji23]
22kgHow many kilos do each of your Bonecrushers weigh?.. the box without the subs will be considerably lighter... and if you use Birch it'll actually be LIGHT... it's only single 3/4" thick material throughout...
I thought it would be thicker than that.Had to do the same. Imagine a 75 lb. box then add 100 pounds worth of subs. ..that's a lot of weight.
---------- Post added at 02:03 AM ---------- Previous post was at 02:03 AM ----------
Maybe 1-1.25"
All dowels I've used have been 1.5" diameter... IDK what your supplier has available... any size over 1" is sufficient just secure the dowel well...22kg
---------- Post added at 06:11 AM ---------- Previous post was at 06:10 AM ----------
22 KG?... your subs outweigh mine...22kg
It'll be sufficient... I'd pre-drill the holes on the end where the screws are going to attach tho... as you don't want to split the material... then screw and glue them well in place...1.2m long 25mm thick. Tasmanian oak.
I always pre drillIt'll be sufficient... I'd pre-drill the holes on the end where the screws are going to attach tho... as you don't want to split the material... then screw and glue them well in place...
you do?!I'v got 2 3m lengths of that eh......
Absolutely nothing. Are you drinking?What ideas are you tryna put in my head mate? Lol.
