Single capable amp needed to push 2 12" bone crushers.
What did YOU do?... adjust box size?... that is not the same as the Torres one
You've created something close to this...
You gonna' go with THAT ^^^^????
It won't fit Bro.. That 35" was way too much my max width I can go is 700mm... I haven't done anything though....
Sent from my MHA-L09 using Tapatalk
Height and depth as well?.. available space please...let me determine the clearance to the hatch... try to go as high as you can within reason... you need to find some airspace...
So far I've got 27.5" wide... I need more info...
I can go a little higher for sure
500 deep 400 high 730 wide in mm.
Goin to build the back board in the mean time so take your time.
Are you SURE this time?... and that 500mm is to the hatch?
400mm high?... that's the max you're willing to go... 500mm to the hatch in depth?.. Or are you trying to account for clearance again... let me account for it...
Those measurement are the maximum for each side..
To be sure we are speaking the same language 4m is width... 3m is depth and 2m is height in the diagram below...
I need MAX usable dimensions... I'll try to do the rest.... except build it for ya'...
Yes I gave you those measurements in the correct way.. I'v removed the battery cover lid.. The max width is now 780mm
That's a hatchback for ya.... The next best thing I can do is remove the battery cover an can take the width to 780mm
How tall are you willing to go realistically?... I'd like more room somewhere... is the box going to be against the hatch if I use all 500mm?
Wellyboy
Wellyboy
AU
Wellyboy
