single alternator vs dual alternators
mensah0077
hello i have 1 240 amp alternator but i need more amps if i add another 240 amp alternator will that help or add 1 400 amp alternator and if i add 2 240 amp alternators make it 480 amps or a strong 240 amps
im looking to power a dd m3b and 2 mtx 3404 amp plus 2 sets of 35 watt h.i.d lights for a 2003 aurora fully loaded i want the volts to be around 14 -15 with out a 16 volt conversion
also i have a yellow top plus a xs power 3100
honestly you may be ok just with a couple more batts with out buying a alt. i would get rid of that yellow top and get a better agm battery for under the hood and another group 31 to go with the one you already have. i have a bc3500d and it drop only to 13.7v @ full tilt and thats at idle, im pretty sure that my amp puls more then your M3b does and my alt is smaller then yours.
and alternator cost 150 another battery cost 350 - 400 plus my hid light take up a lot of juice
---------- Post added at 11:51 PM ---------- Previous post was at 11:50 PM ----------
Do you even have a spot to add a 2nd alternator?
yep can add 2 more if needed
well i mean if you can get a alt for that cheap then i mean that would work
i know how to rebuild them the kit cost 120 but it does not drop bad but when the lights are on its drops to 12.5 i dont like that
i think imma run the 2 alts to be safe
you mean how to rebuild your alternator its really easy thats the 1 i have right now on the car it work fine for my 2 mtx 3404 and a kicker 1500 d with h.i.d lights stays around 14.2 at full tilt
mensah0077
mensah0077
lincoln park
Kevinl
