Singer alt output
speedyjuarez
Premium Member
Premium Member
99 Tahoe
275 singer alt
3x yellow tops
80 prs
I noticed my voltage has been low from my 80 prs VM, I was driving on the hwy and it was reading as low as 12.0 with all a/c on and no subs/amps on. I took it to the local parts store to have it checked. 13.8 with out load 13.2 with load. I replaced the Belt because I heard belt slippage but haven't seen an increase in voltage. My two rear yellow tops are about 2 months old and the one under the hood is about 1 year old.
What voltage should I be seeing with a singer alt?
Should I check amperage?
I have a SMD VM-1 but has it off because I didn't have the subs in the truck and the speaker wire was loose. The auto parts guy checked it at the front battery. Not sure on the regulator part but it use to give me 14.8 all day long on my SMD VM1.
Should I check the alt with batterys disconnected?
Check voltage at the alt. when running. Should see 14+. If not. Possible damage to the regulator
should it be done after you drive and/or play the stereo for a bit..??
i ask cause i think my alt reg is going out.....
best why of checking the voltage, is turn on your lights, ac or heater...
put a load on it then check.
dont really want to play your system when checking your voltage.
ok ive done it that way.. but from a cold start. was around 14.5 but after a couple min of running it was down to 14.1- .0
Before and after could still be a bad battery to. Even tho it's new. That doesn't assure that it's good
speedyjuarez
Premium Member
Premium Member
speedyjuarez
Live in Hobbs, NM. From Ft Worth, TX
speedyjuarez
    May 16, 2024
    May 16, 2024
