Silverado help
Tripn88
I have a 2003 silverado 4.8. When I had my stock 105amp and a duralast battery. I had bad voltage drop. I have upgraded to a 240amp alt and my truck will only charge at 14.4 or higher in the mornings. After it warms up I can't get it over 13.9. I did this with my stock alt also. I replaced battery a few weeks ago. I have a 3 wire plug on my truck. I assume this is just typical and ****** luck haha. Voltage drop is minimum with all accessories on and radio playing. Stays in the 13.7-13.9 area.
Anyone have any experience with this or suggestions. I don't want to go to an external regulator if I can help it.
Its how the stock regulator works. It check the temperature and brings the voltage down.. Mine goes to 14.2 after warmed up.
Most add a diode to the sense wire if they dont want a external regulator..
The easiest way without a real external regulator is xs power vcm module
Sent from my draconis using Tapatalk
Do you know if the xs power vcm will work with 3 wire alternators? It has the oval 4 wire plug but only 3 wires coming from it. I'll email them tomorrow if need be.
I dont know.. From what i know the only non supported were 2006+
Tripn88
Tripn88
Baytown, Texas
los33
