Need a test dummy
K so I don't know much about batteries but what does the phca stand for and why is it rated in watt hours not ah
Pulse hot cranking amp..
Same thing as CA (cranking amp), but works hot when first pull is done due to the lithium needing heat.
These will not work to good with agm or acid battery as it requires very fast amperage rates which would cause the other batteries to live half the original usage rate.
It be best used as a main battery or a system consisting of only lithium.
Recommended charge rate for 12v lithium is 14.5-14.8.
Sent from my draconis using Tapatalk
I'd like to try these, but need to buy new tires for my truck. That's my next few paychecks //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Gonna be honest with you bro.
We have a ton of issues from clients having problems with these charging from normal alts and even more so with HO alts. We are currently in the works on designing a alternator specifically designed to charge Lithium batteries.
Our specific applications are 24v and 48v however, so a 12v battery may be different. But I'd be willing to bet it isn't.
being in the rc helis for the past 15 year the batterys have changed a lot.
now every body is using li-fe/ or lipos .
alot better battery.
faster recharges, light weight , and fast discharge.
and was wandering when they would come out with a good 12v lipo .
and i would NEVER put a amg and lipo together.
dont do it.
ether get all lipos or all amg.
LosIsATool
LosIsATool
Pensacola, Florida
TaylorFade
