Should I ground from the front battery or just the rear?
da box king
Ok so I am running a crossfire vr4000d, a sax 100.4 , and a PPI pc4400.2.
I have 2 pos runs to the back and a 1 neg, all in kicker 1/0. I have 2 deka g31's in the rear an a g34 up front. I am wonderin about my ground tho. I was goin to add another ground in the rear because I don't have enough 1/0 to run one from the front. But will I benifit from running my ground from the front to rear? I have heard some probs when doing so, or should I just do my original plan. Also is it ok to have 2 pos, and only 1 neg from the front, remember too I will be grounding in the rear too so I thought I would be ok, or do I have to to worry about resistance by doin 2 and 1. I'm just trying to decide if I should keep my 1/0 neg run in, or move the ground to the rear? Thanks guys, trying to get some work done tonight.
a common rule of thumb the shorter the ground the better. i would make a new ground in the rear and go to town sanding the paint off and bolting it in wherever you decide to do it.
do you think I should take out my ground from the front battery to the rear than? I hear many people having runs tot he front with no probs, or should I just be ok grounding in the rear?
There is a reason people run them copper is a better conductor than your frame.. Grounding to the frame in the back is just circling back through the frame instead of a through the wire..
I think I may take out the front ground, and get a good ground in the rear....prolly near the seat bolts.....any suggestions for a trailblazer ground
If I wanted to go to the frame I would just drill a hole thru the floor and run it too the the frame right? an I would prolly throw some undercoating on the ground too
or would I be ok to just ground to the body, which I always do. The factory grounds are all over the body
well I could leave it as a power? sorry for the confusion.
and if I did just ground to the frame, does it have to be direct, or can I just ground to the body which goes to the frame?
I'm just lookin for the best most efficient way to do it, thx
da box king
da box king
Portland, MI
balgo
