Should I Get This Amp?
kfx450r
Its a Soundstorm amp, i want to power 3 12" Type Rs to their full abilities..its either this amp or a hifonics 1606D..this one is obviously cheaper..heres specs
2500 Watt 1 Channel Class D Amplifier
Max power 1 ohm 2500W X 1
Max power 2 ohm 2200W X 1
RMS power 2 ohm 1800W X 1
MAX power 4 ohm1500W X 1
RMS power 4 ohm 900W X 1
One Ohm Stable Mono-Block
Strapping capability: Strap two amps together for twice the power
Variable low pass filter: 50 -150Hz
Variable subsonic filter: 15 - 45Hz
Variable 0 to +18dB Bass Boost
Phase shift selector: 0/180º
Variable input gain control
Input sensitivity selector
Power and protection LED indicators
Thermal, overload and speaker short protection
RCA Line Level inputs
RCA Line Outputs for system building
Chrome plated RCA connectors and screw terminals
Remote subwoofer level control
Frequency response: 50Hz - 150Hz (+/- 3dB)
Signal-to-noise ratio: 103db
THD at RMS output: 0.01%
Damping factor: 125+
Dimensions: (10” W x 2-5/8” H x 11-5/8” L)
1 Year Factory warranty
Alright, thats crossed out..im looking at a 1606d and 1608d..Not sure which ill get. How are the crunch 1500w amps? Im obviously leaning toward the 1600s for more wattage tho.
I would say stay away from the Soundstorm..... Then again, I wouldn't run a Hifonics BXi amp either even though I have recommended them to friends as CHEAP power. They were more than satisfied with the performance of the Hifonics even though I think they are cheap and make about 10 to 20% less than their "rated" power at any given load.
Truthfully, I would run **THIS** over a Hifonics BXi 16##D, but that is just me! Heck, I would run it over the BXi 20##D too!
Lol youd obviously run that 500$ amp over a 190$ hifonics.
Well... actually... NO! If I were in the market for a Class D amp, I might run the Cadence, but knowing me I would get something more expensive. Instead, I am going to run some old school, Class AB greatness on my subs @ 8 ohms mono! One of them will put out 850 watts RMS @ 8 ohms and the other one will do 1,100 watts RMS @ 8 ohms. I love me some old school, high voltage, power amps:D
ETA: Go with the Hifonics and call it a day. As I said, they are CHEAP power and very hard to beat for the price!
if i was spending 500 bucks on one i would get a sundown...NOT this...but thats just me:cool:
kfx450r
kfx450r
Hammond, Louisiana
infamous_e46
BP1Fanatic
BP1Fanatic
