Shopping for a AMP, but...............
Kind of a silly question, but maybe someone here can clear this up for me.
I am going to be buying a custom box with (2) 10" subs, they are both 4ohms and RMS that I need to provide to each woofer is 500 watts rms.
What I am looking for one (1) single amp to push both of these subs.
Now do I need to look for a mono-block type amp or a 2-channel?
Would these specs work for my application:
Xxample:
An amp that is 1500W, is a 2-Channel which has an Power Output of:
375W Maxx x 2 @ 4 ohms
750W Maxx x 2 @ 2 ohms
1500W Maxx x 1 @ 4 ohms
Would this amp with these specs work for my application of SUBs I will be using 2-subs @ 4ohm each to gain at least 500watts rms?
If not, what kind of amp / spec wise will I need to look for to gain the most power? //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Thanks all.
I am looking to spend ruffly about $175.00
The two amps I am looking @ are:
AutoTek AT1500 & Power Acoustik LFA2-1800
From my understanding and reading about Ohm loads.
I can have (2) 4-ohm subs, then run on each sub (-) to each other then the (+) to each other then on a amp, if it is 2-ohm stable, I put the (-) to the amp (mono/bridge) (-) and the (+) on the (+) on the amp (mono/bridge) and it will make both my subs go into a 2-ohm load. Is this correct??
Like this:
i he has 2 single 4 ohm subs he needs 1000 rms at 2 ohms bro //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
your right //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
i was thinking dvc //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
im tired
Ok.... the subs I am going to be running are the Credence 10s
Info on the sub: //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
Basket Material Cast Aluminum
Basket Finish Black Powder and Machined
Magnet Weight 84 oz.
Magnet Structure Weight 12.59#
Magnet Material Strontium Ferrite
Cone Body Material Talc Filled Copolymer
Cone Edge Material Black Butyl Rubber
Voice Coil Diameter 2 ½"
Voice Coil Wire Type 4 Layer round, high temp
Voice Coil Former Kapton with double reinforcement
Extended Pole Yes
Vented Pole Yes
Compression Terminals Yes
Primary Box Type Sealed or Vented
Dust cap Style Specialty
Dual Voice Coil Yes
Power Rating RMS Cont. 350 Watts
Max Power Rating-Unclipped Amp 800 Watts
Freq Response 20-150 Hz
Nominal Imp 4 + 4 Ohms
Voice Coil 2½" 4 layer
FS 25.59 Hz
Qms 5.674
Qes 0.3936
Qts 0.3681
Vas 34.64 Liters
Cms 2.199E-04M/N
Re 7.43 Ohms
BL 23.105 Newtons/Amp
Sd 0.033491 Sq. M
Mms 0.175894 kg
Hvc 1.200"
Hag 0.375"
Xmax 0.413"
Xlin 0.825"
Ref Eff 0.1417%
Predicted Output 83.715 DB/1W/1M
Extended Pole Yes
Vented Pole Yes
Dual Voice Coil Yes
FS 25.59 Hz
Qms 5.674
Qes 0.3936
Qts 0.3681
Vas 34.64 Liters
Cms 2.199E-04M/N
Re 7.43 Ohms
Sd 0.033491 Sq. M
Mms 0.175894 kg
Hvc 1.200"
Hag 0.375"
Xmax 0.413"
Xlin 0.825"
Ref Eff 0.1417%
you need 1000 rms at 1 ohm then not 2 ohms neither of the amps u said will do that.
the at2000 will so will the gpv 2000.1 lemme know if ya want 1 i have a warehouse full of them //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif 160 shipped
sicaudio@msn.com
Slap_my_momma
Slap_my_momma
Lockhart, TX
SicAudio
