Shiva and what AMP?
with a 600.1 and a single shiva wired in parallel you will get a 4ohm mono load giving you 300watts rms out of your 600.1. i think the biggest reason bootleg is really stressing getting the 1200.1 is b/c at 4 ohm you get 600watts rms and if you add a 2nd shiva you will get 600rms a piece. now if you run 2 shiva's off a 600.1 in a parallel setup that will give you a 2ohm mono load giving you 600watts rms to the pair. i think that explains it rather well i'm not sure why no one straight up said that before but hope that helps ya bro.
adam
hey no problem man i was just wondering why nobody broke it down for ya before me. i still say 1200.1. save the extra what 75 bucks and get it man you will like the power a lot more.
adam
alright shivas are daul 8 ohm coils so it you wired to 4 homs a jbl 1200.1 would do fine. a 600.1 would only give 300rms at 4ohms. go with the 1200.1 and a shiva then save up for a speaker amp later.
wire the subs so you the amp is giving the pair a 2 ohm load, and with that amp, you will be giving them 600 RMS (the pair) and 300 each (this is what their listed RMS, 300 each RMS). Maybe even some more than thatm I hear that they under-rate the JBL amps.
with those shiva's....be careful....might want to put a fire extinguisher or sprinlker system in your trunk.....people have been having problems with them catching fire //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
probably from putting a 1200 on a single sub, like many people like to do, and giving them way too much power. thats 600 watts RMS to a 300 RMS sub, not too good!
Originally posted by PitySister with those shiva's....be careful....might want to put a fire extinguisher or sprinlker system in your trunk.....people have been having problems with them catching fire //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
no ones having problems havign them catch fire..
at least noone who can document them or give details..
jsut hta tone prick from the other thread..
hes an idiot, dont listen to taht guy....
SpeeDFX
SpeeDFX
Altadena, CA
Mr. Loki
Doxquzme
    Jun 20, 2026
Doxquzme
    Jun 20, 2026
