shallow design. . ok?
sporty_drew
Just here...
I'm wondering if this design will work. I'm thinking of having the two subs that are furthest towards the front of the box mounted normally and the back two inverted. The box would have a divider down the center so there were only 3 subs per chamber. My only worry is that with such a shallow back the inverted two (back two) would not see the same amount of airspace as the front two. It'll be made out of 3/4" and all of the measurements are outer ones. What do you guys think?
Thanks, Drew
I don't know, That seems awful thin if those are external dimensions...
I can't say for sure.
But I believe that will effect the ones that will be inverted.
Maybe somebody else can give a more certain answer.
~Magick_Man~
Yea, i was hoping someone could give me a good minimum depth that i could go off of for the inverted ones.
I could do 4 inches (2.5 inches internal) would that be enough? I know that i'll loose a little output no matter what compared to the other two, but that is to be expected from where they are placed in my car also.
sporty_drew
Just here...
sporty_drew
Iowa
sporty_drew
