setting gains
gotcha--- and when i turn the screw both ways it wont ever come to a stop-- is it suppose to be like that
What screw? The gain knob? It should stop, twice actually. Use the gain setting tutorial mentioned above to figure out the desired voltage. Put in your test tone, turn to the desired volume (without clipping, with subwoofer control at the normal level), put the DMM on the speaker terminals with no speaker wire attached. Then turn the gain knob slowly until the voltage is at the right level. It is not as complicated as it sounds, but reading that gain setting tutorial will help you greatly.
mattyg2310
mattyg2310
tacoma
mikeyboc
NorthFramingham
    Jun 30, 2026
