Setting gains with multiple devices
It is essentially a high pass filter and I believe it has a steeper slope than a HPF. You should generally set it to 1/2 octave below the tuning frequency. So if your box is turned to 36Hz, 1 octave below that is 18Hz, half of that is 9Hz, so you'd set your subsonic filter to 36-9=27Hz.
Generally speaking, if you think your LOC has enough flexibility, take out the x-over. There are acoustic disadvantages with having additional components in your setup. However, if you think the x-over gives you the needed additional flexibility, then leave it. If the LOC already does everything you need it, remove the x-over.
Ok I prefer to have the crossover in place because I have a remote gain control (for the crossover) mounted up front and my gf hates the bass so I like being able to easily turn it down for her.
Here's what I found on the net for my devices. Can I mathematically determine the approximate gain setting based on each devices specs?
re-q:
re-Q Specifications
Gain dial has 0.0-2.5
In spec sheet:
Output Channels: Left, Right, Sub
Output Type: Unbalanced RCA
Max Output Voltage: 2.5V RMS Full Range, 8V RMS Sub
Signal to Noise: >90dB (A-Weighted referenced to 1V out)
THD+N:
Crossover Sound Storm SX310
http://images.soundstormlab.com/manuals/SX310_EN_UM.PDF
Output voltage: 8Vmax
Output gain: 1:2 +6db
PPI A600.2 art series amp
http://www.precisionpower.com/Manuals/Amplifier%20Manuals/Precision_Power_Art%20Series%20Axxx.2%20Amplifiers.pdf
Input Sensitivity: .2 - 2.5 V
You should set everything at 2.5V. If you're able to select the output voltage on the x-over, set it to 2.5V. If you set it higher, you will overdrive the signal as your amp only accept 2.5V max. Consequently, as noted earlier, you will need to set your amp to the minimum sensitivity setting.
re-q:re-Q Specifications
In spec sheet:
Re-Q outputs 0 to 8V? And same with crossover? So should they both be at about 1/4? I am now using the sub output on Re-Q.
The deck has only a volume knob. (it's a factory radio)
The Re-Q has a dial from 0 to 2.5
The crossover and amp have no numbering on their dials, but I believe we know the output ranges?
With that, can you tell me the approximate setting (from 7 o'clocl (lowest) to 5 o'clock (highest) Is there any way to see what the output voltage is with a multimeter?
The PPI has a max input sensitivity of 2.5V, so if I set the other 2 devices to what I believe is 2.5V, where should the PPI amp be set at? 0\7o'clock?
Sizzlechest
NJ
bigmizzle99
