setting gains help
tyoung87
NC
hey i have a saz 3000D running at 2 ohm... i used a DMMto tune it with 50hz test tone was wondering if this is correct.. 56.57v tuned too, also was wondering what would happen if i turned it up a little louder?
That's about right. Turning it up a bit won't kill you. Besides, you set your gains with a test tone and your music will never see that peak anyways. Using a DMM is the safe way to do it. Doing it by ear can get you more. But since your amp is underrated, you can turn it up a litle and be fine. What I like to do it turn my sub level at my deck a few clicks lower (like 13 out of 15), and set it there and if I need more, turn up the sub level instead.
tyoung87
tyoung87
NC
tyoung87
michigan born
    May 14, 2026
michigan born
    May 14, 2026
