Setting gains by ear for subwoofer
MellowHype
Whats the first sign of distortion from a sub when setting gains? My DMM is playing up, and i want to set my gains. Is it best to use a test tone? What kind of distortion would i hear? Bottoming out?
Thanks
HU - CDA 117ri
Sub - Type r 12" dual 4 ohm -@ 2ohm ---- Ported box 2cbft @32hz
Amp - Kicker ex1000.1 700wrms @2ohm
lol, guess i shouldnt even try?
No it takes a lot of experience to set gains by ear. Even when an "Expert" does it most likely the amp will either be slightly clipping or not putting out its full potential. 20 dollars and you have a cheap dmm which will do the job.
Just tried my DMM again one of the wires was loose, the gains are set at 700wrms still, using a -3db 60hz tone. I just played the tone at my max undistorted vol, and it shook my whole car and my rear view mirror moved all the way down. However when im actually listening to music, its no where near as loud. Is it safe to go with a -6db tone?
Should use a 0db 50Hz test tone and set it to play that tone at the volume you listen to or the highest volume you listen too. There is a huge tutorial on it.
MellowHype
MellowHype
Uk, London
quackhead
