setting gain via dmm
soskie
sub-1150 rms 4ohm dvc ( its wired to 8 ohms)
amp- 2x 400rms at 4 ohms (have sub bridged, so 800 rms)
Im trying to find out how many volts i should set the gain to.
Do I use the subs resistance or the amps?
Sqrt(Power*Resistance) = Voltage
Sqrt(800*8) = 80
Sqrt(800*4) = 56.56
Thanks in advance:)
sub-1150 rms 4ohm dvc ( its wired to 8 ohms)amp- 2x 400rms at 4 ohms (have sub bridged, so 800 rms)
Sqrt(800*8) = 80
Sqrt(800*4) = 56.56
Thanks in advance:)
The answer is "yes"....because they are the same. The amp doesn't have resistance, the subs present an impedance load on the amplifier (in this case, an 8 ohm load), so that's the value you use for your calculation.
And to the second poster, he's probably got it wired to 8 ohm because his amp can't handle a 2 ohm bridged load...duh
Then why not wire them in parallel to attain a 4ohm bridged load?
Each coil is 2ohms or 4ohms?
If the OP states his only two options are 8 ohms and 2 ohms, then obviously he has two four ohm coils. this thread isn't about how to wire the subs. its about how to use a DMM to set the gain.
You're right this is about helping him, and if his are dual 4ohm voice coils, he can attain a 4ohm load.
soskie
soskie
hell
BlactimusCrime
vegang
vegang
