dab86
Question. What is the current volts my amp should be putting out for the following setup?
Two dual 4ohm subs.
Wired to 1ohm load.
Subs are rated at 500rms each (1000 rms total).
Amp is mono 1000 watts rms at 1ohm.
What should my voltage be set at when using a multimeter? Test Tone is 50hz.
Should it be 31.6 volts or 63.2 volts?
Thanks!
Two dual 4ohm subs.
Wired to 1ohm load.
Thanks!
