trabadoor22
I have an older directed audio 1100d running at 1 ohm to a single elemental designs e5.12 sub, which at 1 ohm provides 1100 watts. Not sure if I have it right, but doing the math I came out with 33 volts @ 50 hz which I set it at. There is good output on rap, but I mostly listen to rock music and it's just not as much output as I'm used to. I just replaced the older elemental designs 130v2 which blew after a new install and I see why. My new hu must have been sending a stronger signal and the amp was running at around 70 volts while doing a test tone. Before I had the gains set at close to 3/4 way, now it's at 1/4. It was insanely loud while it lasted. Anyways my question is could I turn up the gain a little bit seeing as I don't really listen to test tones and rap a lot?
