Selenium PA setup need some input Front Stage and Rear Stage(fill)
siviog1
Team Bass in Your Face
My current setup consist of (2) Selenium 8W4P and (1) Selenium ST350 per door - Nexus 7 as headunit with Clarion EQS746. Car is a 2006 Dodge Charger.
The list below is what I am leaning towards. I will be doing the majority of my own glass work and yes I will be purchasing a Pioneer DEH 80PRS to run active. I need to first figure out the speaker configuration then move towards the amp purchase.
Front Stage - Front Doors
Option 1
(3) Selenium 8W4P and (1) Selenium ST350 per door
Option 2
(1) Selenium 10PW3-SLF (2) Selenium 8W4P (1) Selenium ST350 per door
Rear Stage
Option 1 - Rear Deck
(4) Selenium 8W4P and (2) Selenium ST350 in rear deck
Option 2 - Rear Deck
(2) Selenium 10PW3-SLF and (2) Selenium ST350 in rear deck
OR
Rear Stage - Rear Door
Option 1 - Rear Door
(1) Selenium 10PW3-SLF and (1) Selenium ST350 per door
Option 2 - Rear Door
(1) Selenium 8W4P and (1) Selenium ST350 per door
Id run it this way:
Each front door:
2 Eminence Delta 10s
1 ST350
Each rear door:
1 Delta 10
1 St350
Rear Deck:
2 Delta 10s
2 ST350s
Run a Lanzar OptiDrive 700x2 on the mids, with 4 mids per channel, wired to 2ohm stereo. Something smaller on the tweeters, that will do around 250x2 @ 2ohm. These crossovers settings should get you close, then just EQ from there:
Mid HPF:
100hz
24db/oct
Mid LPF:
4.15khz
6db/oct
Tweeter HPF:
3.15khz
24db/oct
Ive ran many setups with Selenium and Eminence, among other brands. Between the options you are debating, the Deltas are better speakers hands down. I had almost this exact setup in my doors, with an 800PRS, and these settings with some EQing got myself some KILLER sound. Very smooth, quality, flat, and loud.
Id run it this way:
Each front door:
1 ST350
Each rear door:
1 Delta 10
1 St350
Rear Deck:
2 Delta 10s
2 ST350s
Mid HPF:
100hz
24db/oct
Mid LPF:
4.15khz
6db/oct
Tweeter HPF:
3.15khz
24db/oct
Thanks for your reply... I was trying to stay with Selenium since I already had the brand but since you have the experience with both drivers. Then I guess deltas are the way to go... Dope vids on Youtube been following you for a minute...
These are the deltas model your speaking of... Eminence Delta-10A 10
http://www.parts-express.com/pe/pshowdetl.cfm?&Partnumber=290-412&scqty=8
Yes, I know my car was dirty... This picture was taken a few months ago....
This was the first time I have ever done any fiberglassing and it was in the middle of the winter with no heat. (2 years ago)
all your options will work. I'd base it more off what will be the hardest to install/implement. The selenium 10's get quite loud. Joker's Caddy has a single 10 in each door and keeps up no problem and he does mid 50's on music...
siviog1
siviog1
CHi-Town
mlstrass
