Second battery
ashtrey1212
Gimmie Some Sugar Baby!!!
Can anyone shed some light on how I go about hooking up a second battery inside my trunk? I want to push some serious power out of my system and I think I'm going to have to ditch my cap and get another battery. I already beefed up my alternator to a 160 amp and the battery under my hood is an optima red top, I just need to know where to go from there.
just make sure u bolt it down well, run wire front primary to secondary (fuse it) and hook amp up to second battery
u can run a ground front front batt to 2nd or just groun it real well to frame
So its pretty much the same way I got it right now, just instead of a cap I'll have a battery?
yep.. but with bigger cable hopefully
Well I got zero gauge as it is. Should I go any bigger than that? Can you go any bigger than zero gauge? Also, if the battery is just going to act the same as a cap would than why not go with a bigger cap?
fuse at front and rear batteries. + from front to + in rear. - from front to - in rear (or just ground both to the frame/chassis)
You bring up a good point. When adding a rear batt, always fuse BOTH ends of your positive cable connecting the front and rear batts. People get use to only fusing the front and forget that they now how a power source at both ends of their wire. A short could/would draw current from either batt, at either end of the wire.
OK so I already have the fuse at the front battery. When I fuse the second battery do I put the fuse on the cable connecting the two batteries so I would have two fuses on the same cable? Or do I fuse the cable running from the second battery to the amplifiers?
ashtrey1212
ashtrey1212
Amherstburg, ON
jrwalte
michigan born
    May 14, 2026
michigan born
    May 14, 2026
