Static, gotta hate it. New install. How to diagnose? ITS LOUD!
Just started installing my 2 new set of Pheonix gold RSD 6.5 components, tonight I only had time to run all the speaker wires and connect 2 of the tweeters, and both are giving off HEAVY static, that increases when you turn up the volume, but starts becoming audible at like volume 10, and very heavy at 20+
All the other speaker connections are left unconnected but these 2 tweeters are hooked up to my 4 chanel amp, gains turned almost right off, full pass, great grounds, good twisted connections at those tweeters
My deck is a premier 860mp and I have my rear fill running off of the deck and they sound perfect.
I should maybe mention that Im running 2 sets of RCA's to my speaker amp, one coming off the "MIDS" rca output off the HU and one coming from the "HIGH" rca output from the HU, dunno if that matters.....
Im gonna carry on and install the door pod with the rest of the speakers and tweeters tomorrow, I dont know if they will be making the same noise or not but I hope not.
Any input would be greatly apprecaited
thanks
should probably mention that I already checked polarity, they were wired correctly the first time but I still tried to reverse them at the tweeter and it made the same noise, sounded exactly the same
ya the noise does increase when i turn up the volume, like I said
And for conections grounding out, I dont think any are, solid connections from my amp to my crossover board (have them all screwed side by side), then I ran all my wires with new wiring under the carpet and through a gromnet into the door. Like I said only 2 connections were made for the tweeters, and the rest of the wiring is left hanging in the air with no exposed wire
dunno if I should comintue or not with the install or fix this problem first tomorrow, need ideas though
WOT
Banned
WOT
Toronto,CANADA
jrwalte
michigan born
    May 14, 2026
michigan born
    May 14, 2026
