2/0cca
amp needs a 160A inline fuse but they dont make a ANL 160A so I use a 150A.
So what's it going to be? two 150A or two 75A fuses?
If you hook up two 150A fuses in series' date=' it doesn't become 300A does it?[/quote']
The battery fuses aren't there to protect the amp, they're there to protect the wire. Your 2/0 CCA can handle ~350 amps with no problem and I would fuse it at 300. and no, fuses don't add when in series. The reason for having one at each end of the battery wire is that if you have a short in the middle, there will be current flowing from each direction so you need to protect the wire at both ends.
