Second Battery and Amp Grounding
HomeLite
I'm putting in a second battery into my trunk. Would it be better for the amps to have separate grounding points on the chassis, battery and amps grounded to the same point on the chassis, or the amps connected directly to the negative terminal of the second battery and then grounded to the chassis? Thanks y'all
I have a 2018 f150, looking to keep factory head unit, not running a dsp as this is budget build. I have a t harness, skar doors, amp and subs...
So, why the fukk is the pedo replying to me? He started the shitt again and I am responding. What don't you understand?
75
9K
540
HomeLite
HomeLite
Esparto, CA
Mayhem
Decebal
    Jun 10, 2024
