Gregulate
I have a Audiopulse EPD210 EPIC 10" DVC Subwoofer 2 Ohm
Overview
Specifications: *Power handling: 600 watts RMS *VCdia: 2" *Impedance: 2 ohms per coil *Fs: 25 Hz *SPL: 84.8 dB 1W/1m *Magnet weight: 140 oz *Vas: 1.62 cu. ft. *Qms: 3.80 *Qes: 0.37 *Qts: 0.34 *Xmax: 22 mm *Dimensions: Overall diameter: 10.97", Cutout diameter: 9.50", Mounting depth: 5.62".
Highlights
600 watts RMS power handling
Dual 2 ohm voice coils
22 mm Xmax
Long throw 2" voice coils
8" linear suspension system
2" peak to peak travel
One piece anodized aluminum cone
I've got a request for a box quote out, but have read that a lot of you build your own. Building a sealed seems pretty straight-forward, but when it comes to designing a ported/slotted enc, all the info is daunting. I've played around with winisd and some other calcs online, but am not really any more confident. Can anyone advise me on how to get started. Since I'm such a novice, is this more than I should take on or am I making this a lot harder than it needs to be.
Like I said, I'm waiting on a box design quote from Pro-Rabbit, but would like to see what else is out there on "build your own" options.
Any help is appreciated //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Overview
Highlights
22 mm Xmax
