Sealed an Equalized Vs. Ported?
Omarvelous
Was wondering....
Since equalizers are used to give you the frequency you want.....
Coud you use a Sealed sub along with an equalizer to get as loud as if you have used a ported enclosure?
This is why i ask
I want the 15" XXX. I also want my trunk space!. Planning on doin a fiberglass enclosure in my spare well with a false floor. I could get at least 2.8 vol out of it.
I also want ported, but i would have to settle for the 12"XXX, which i won't mind, but i'd PREFER if i could get the 15"
So do you think that if i had a 15" xxx sealed with a frequency, i can actually make it louder?
Or you think i should just go for the 12?
Just want to make sure!!!
Honestly, I wouldn't go that small. You could always try the 12 XXX if any of those sizes with that small of a box.
Personally, I am going with a RE XXX 18 Quad 1.4 in a 8.5 cu ft box tuned to 33Hz. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Powered by a Crossfire VR2000d amp //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Should move some air.
I would take the equalizer out of your question all together. You have the wrong idea on how it effects your musical reproduction. The xxx is a huge driver. If you are worried about space you may wan't to look into something a little smaller. What are you trying to achieve with your set up?
I wanter the 15" because mainly it will look better in my setup.
Also was thinking should i decide to F*** the trunk later on, would have built a large ported enclosure for it, even if it means takin up 3/5 of my trunk.
So wanted the 15" for the long run.
But you think 2.6-2.8 vol is enough for the 12" xxx ported?
Omarvelous
Omarvelous
Queens, NY
Omarvelous
michigan born
    May 14, 2026
michigan born
    May 14, 2026
