SB Acoustics SB17NRX35C/ Vifa DX25TG05/ Need Help
Millertime1028
Allright so , I will be going active fairly soon with the 880 but I am in a dilema with which speakers I should run . Im currently running Pioneer Premier 520PRS's passive . Ive been looking to get a bit louder and will be making fiberglass pods for whichever drivers I get next . Now , I know PRS's sound great ran active when crossed around 3- 3.5k hz which is what these drivers I have linked seem would seem to like
http://www.madisound.com/catalog/product_info.php?products_id=8302
http://www.madisound.com/catalog/product_info.php?products_id=1115
.. Now I would like try to keep the Pioneers in the doors as they are(midbass is excellent IMO) but would also like to use (2) SB acoustic mids (1) Vifa tweet per door in the fiberglassed pods . Now even though it seems im not one for imaging, dynamics, depth, and all good stuff that IS my MAIN concern. Staying well imaged while have exceptional clarity at higher volumes . Do I get rid of the PRS's all together and just run the SB acoustic drivers/ Vifa tweets ETC... If someone has info on these drivers/tweets i have listed and is willing to help me out a little I would highly appreciate any help or info . Thanks
hmm, yea I seen the tweet review from zaph but I couldnt find the review for the SB . I just want to make sure this will fit my needs . Just looking for pretty good SQ but able to get loud enough to keep up with the substage .. 1 comp set is not cutting it . Trying to figure out ow I will situate the driver in the truck also ..
I was looking into those tweeters as well, the Sb mids are 8ohms vs 4 ohms for the pioneers.
the sb mids are 60 watts into 8ohms.
What are your pioneer mids rms @?
How many watts are you watts per channel on your amp?
I think you should keep mids that you have already, maybe look into a more powerful amp.
maybe try out the vifa tweeters & let us know how they sound
remember placement & deadening will make the biggest difference
Yea doors are deadened and sealed, 30-40 sq/ft on each door with acoustic foam and non hardening clay. Mids are seeing around 80 rms right now HP at 63hz/12 db slope. They are rated at 50rms . Believe me they get loud and clear but they are smalll drivers to being with and cant keep up with the substage when its at full tilt . I currently have 800rms on tap for the highs.. 400 per side . Two amps
maybe look into rianbow mids? This one is an 8inch slim
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=7195
or
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=7055
I have heard rianbows, which are nicer then the pioneers mid bass & louder.
If you do try these from woofersetc.com & you dont like it you can return to try something else out.
The same for partsexpress.com
plus they ave a pretty good warrant.
most mids cant keep up with your bass unless you go for a three way system.
I have my sub turned down right until i can get a bass knob so that i can control it.
I wish I can fit an 8 or even 10's but I cant due to the design of the Jeep . Way to many things will get in the way if I go with a driver that big . So the biggest I can go with is around 6 1/2 mid . Thanks for listing those though . I appreciate the recommendations. Ill have to look over on DIYMA also .
only downside about that tweet is that the mounting flange is huge,
other than that, its an awesome speaker, i have its cousin, the xt25 ring radiator version, and they sound amazing in my car (i have 3 per side)
idk about the mid though, perhaps look in hessdawgs thread, hes selling the id oem cx64 mids for 90 shipped /pair and ive heard nothing but good about them....
make sure you know the depth as well, you can just take off your door panel roll down your window measure it from the window/glass to frame then add how your he depth of your MDF rings will be. the placement of the driver & door panel only need to be a little more than an inch.
you can also look into
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=296-410
I had a pair of the 7 but they where to deep, the upper mid was one of the best I've heard for a two way.
make sure you know the depth as well, you can just take off your door panel roll down your window measure it from the window/glass to frame then add how your he depth of your MDF rings will be. the placement of the driver & door panel only need to be a little more than an inch.you can also look into
hes building pods so depth shouldnt be much of an issue....
shouldnt be...
turn down your sub...
Millertime1028
Millertime1028
Long Island, New York
okiedokie
Old_risk
    Jun 23, 2026
Old_risk
    Jun 23, 2026
