Saturn Wiring Help!
JD18
Here's the basics of my problem. I wire up my receiver to the factory wires and I get power, but no sound. I don't have a pw antenna, so what do I do with that wire thats coming from the receiver (blue)? I also have two loose factory wires, whats with that (brown and green)? To some it all up, I need major help, and I regret not listening to my friend and getting the wire harness, but I'm stubborn.
I have a 94 Saturn SC2 and they use the GM wire harnesses and dash kit. I got mine from Best Buy if you have a Best Buy near you. They can give you everything you need for like 60 dollars (dash kit, harness, antenna). However, if you have a receiver with a large mounting depth, make sure you use the biggest front plate that they give you, I believe it is one inch. This makes your receiver stick out more, but it has to be that way.
JD18
JD18
Sarasota, FL
lexus rx
