2000 Camry Alpine HU Install
chinsk
I would like to replace the factory CD player in my 2000 Camry with the Alpine CDA-9813. I know that it is best to wire this headunit directly to the battery with at least a 12 ga cable. I was wondering if any Camry owners out there know of the best way to run this cable fromthe battery to the headunit. I would prefer not to make new holes in the firewall if at all possible. Any installation tips would be very helpful.
BTW anyone know what the going rate for a used double din Toyota stereo these days?
look under your dash on the left side where your left foot rests. there should be a place in the firewall where all of your wiring goes through your firewall. take your tire off and pull the plastic wheel well out to where you can see your wiring. a friend of mine wanted to run his as well without cutting into the firewall and if my memory is correct that is the way he ran his. that way you can run your wiring through the firewall and into your engine compartment.
chinsk
chinsk
Atlanta, GA
chinsk
