SA-8 vs. 1508???
Suspension travel can be important, but like any other aspect of a speaker, its importance is limited. For burping, sure all suspension travel is useful (provided the coil can withstand the power needed to get that suspension travel). But for actually listening to, as in music, you dont want to consider your entire xmech as usable. Anything past xmax (70% of BL at resting pos.) will not be linear, and distortion will become a larger and larger factor.
The coil of the SA-8 can't bottom out but you can hit the triple joint ring against the top plate (there is a ring under the spider that supports the triple joint and makes it nearly impossible to break) if you move the driver far enough to actually stretch the spider material a little bit... I tooled the small plastic ring under the frame to increase the distance for this to happen but we've done it on 2500+ watt burp.
Tommy,
If I was building the 8s here I'd have them sanded to bare metal (I do that when I re-cone them and I also use CA glue) -- since I am not making them here it came out simpler to tool the steel bolt down ring -- it's easier for the build house to do the ring than add sanding to the build process. They could also do the epoxy trick but as you have noted that can still be broken with enough abuse!
The spider glue is really fairly strong (not as strong as CA glue but works well in general) as it never fails on SA-12s but the 8s have just as much motor force with MUCH less glue surface area to hang on. The bolt down ring will take care of heavy abusers like us //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
As for making the spider stiffer... I could stack two spider packs (they are already two spiders laminated) and cut the leads off of one so they stack (as they come with leads)... that would be absolutely ridiculously stiff but we can try it at some point.
Oh yah - pics of the bolt down ring :
It sits on top of the spider insider of the top lip on the frame and bolts in from the back - this way the cone can't come down and smack the bolt heads.
would sa-8's be able to go sealed. i want to go sealed thats why im getting rid of my 1508's
I would stick with the 1508 sealed -- the much higher Qts makes it a better option for sealed, IMO.
Some folks run the SA-8 sealed and like it but it really loves being ported.
I have the D4 sample (I cut off and re-glued the cap on the D2 so it has extra mass now) that I can send your way for testing -- that work ?
Whatever works for you. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
As for the spider thing, are you making recones for these in house? Because I really would be interested in trying a stiffer suspension as I get it to bottom out before I do any damage to the coil which leads me to believe that I can squeeze a little more out of it. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
O.G. D-Wet
[]D [] []v[] []D
O.G. D-Wet
Maple Shade, NJ
sundownz
BP1Fanatic
BP1Fanatic
