RyanM923's Dual Reflex 6th Order BP build...whew.
From my experiences, it usually doesn't work out too well to have short ports. Longer (while keeping the tuning high) usually equals louder. Curious to see what this thing does though.
I thought about that too, but since the box is being tuned so high, I already had to make the ports very large. In order to have them, say, 15 inches long...they'd be nearly 6" wider and as a result take up a lot more space as well. I was just wanting to work with a 49" wide design(since 4x8 sheets of MDF are 49" wide) in order to make the build easier.
That's awesome! I would love to know how that sounds! Get some videos soon!
Well I'm still waiting for my truck to get out of the shop...I have no idea when it will be ready.
all done...not too shabby looking.
well, I got my truck back today and got it all installed...
What a freaking disappointment...I've never been more frustrated in my life. It's probably doing a 145 around the 47-48hz area. I'm thinking my rear chamber is tuned too low, and is amking it pretty loud over a fair amount of frequencies(doesn't drop off sharp like it should). What could I do to raise the tuning of that rear chamber? Shave the port down? Add some 2x4's to the inside?
What a freaking disappointment...I've never been more frustrated in my life. It's probably doing a 145 around the 47-48hz area. I'm thinking my rear chamber is tuned too low, and is amking it pretty loud over a fair amount of frequencies(doesn't drop off sharp like it should). What couple I do to lower the tuning of that rear chamber? Shave the port down? Add some 2x4's to the inside?
you mean raise the tuning... and id try to cut the port down before i tried adding volume to the box
P.S. bandpasses are a bish to design //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Yeah, I meant raise...edited it.
I'll probably try cutting the port down first, but I'm having a hard time thinking of an easy way to do it....anyone have suggestions?
cut some of the rear port..about 4inches and that should raise ur freq a great deal
and should bring u closer to ur goal
80
be4 u start cutting turn the phase on the amp to 180 and see how that works
840
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
833
941
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
RAM_Designs
SketchUp Master
RAM_Designs
Rockwall, TX
RAM_Designs
    May 16, 2024
    May 16, 2024
