runs of wire question
ok thanks so much, and heres my last question. Say i wanted to do two runs of 1/0, i would have two runs going from Battery1 + to battery 2+ and then two runs going from battery 1 - to battery 2 -, (would i need two runs for the negative?) and then also would i have to use two runs of the 1/0 to go from + and - on battery2 to go to the amp?
The negative wire will need to be the same size as the positive wire. 2 positive wires means you need 2 negative wires of the same size. 2 wires for the pos and neg between the batteries may be overkill... it's hard to say without knowing what you're doing.
I don't think you would need 2 runs from the 2nd battery to the amp. I'm not certain of ampacity rating of 1/0 wire, but mine came with a 250 amp fuse. You would have to have a really huge amp to need more than one run of 1/0 into the amplifier.
ok thanks so much for everyone who helped me. i believe i know what im doing now //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif im going to run the wire how it is in the first picture i drew, add a fuse from battery2 + to amp +. The reason why i asked is because i plan on getting a amp that does around 3000-4000 watts, but just wanted to have my electrical upgraded first.
The first pic looks fine to me, including the fuse locations. I would ground the amp to the second battery. You may want to fuse the + wire from the 2'nd battery to the amp.
x2 ^ , 1/0 wire will do for about 300 amps on a 20 ft. run. If you only use about 3000 watts you should be fine with one run. (depending on the amps eff.) I personally like to go + to + and - to - but it gets expensive with multiple runs. You can just ground to the chassis and upgrade stock ground with same size wire. If you end up with 2 1/0 grounds to chassis in rear, you need 2 up front also. Don't forget the big 3!
you should equal amount of wire for pos and neg. also a chasis ground is really not needed. just bring the amps ground right to the battery and then bring the alternator ground right to the battery
woodplock7
woodplock7
Florida
PSturmer
ThxOne
    May 25, 2026
