Running tweeters off of DEH80 PRS then using 4 channel amp for sub & 6.5's in active?
  • 1
I'm using Pioneer DEH80PRS, kicker kx 650.4 & CDT es62 components along with a hertz 10 sub.
So will the tweeters have to be soldered into the radio harness adapter here (ipp-756)?? I'm guessing front left & front right? Following the user manual (deh80 prs) it gives me the Green & Violet (+ and -) as the high range speaker??
https://www.scienceofspeed.com/index.php/nsx/ipp/stereo-system-accessories/scienceofspeed-proformance-harness-adapters-for-nsx.html
Then just use the rear & subwoofer RCA outs to my 4 channel amp?
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
461
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
Thanks for the feedback. It was a long shot but there will definitely be much more powerful subs in the trunk, so clearing it out isn't an option...
s2g-unit
s2g-unit
NY, Redding, CT & Montreal
s2g-unit
    May 12, 2024
Brendon Jenness
    May 11, 2024
