Running a Powerus 10k half ohm edition at 1.3 ohms?
  • 4
What are the downsides of running a .5 ohm stable amp at 1.3 ohms? I saw that they make less power at or above 1 ohm?
If you have 1.3 ohm load why not buy the 1 ohm version of that amp?
The difference running higher impedance with most of those half bridge amps is not all that great so you're leaving some potential power on the table but it may or may not be very dramatic.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
343
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
Thanks for the feedback. It was a long shot but there will definitely be much more powerful subs in the trunk, so clearing it out isn't an option...
Kyle.gardner00
Kyle.gardner00
New York
hispls
vlusardi
    Apr 27, 2024
    Apr 27, 2024
