Running 4v preouts to amp that only accepts 2.5 v
kcr357
ft laud
I stashed a couple mmats amps for my next build, and just noticed the manual states itll take up to a 2.5v signal. Havent seen any hu with less than 4v for awhile now. It this going to cause damage? These amps were fvcking expensive.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
497
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
Thanks for the feedback. It was a long shot but there will definitely be much more powerful subs in the trunk, so clearing it out isn't an option...
kcr357
kcr357
ft laud
kcr357
    May 18, 2024
    May 18, 2024
