Rookie Questions
tytler32u
I am ready for a system in my wifes 2003 Navigator. Right now, there are stock 6.5 components in the front, Im assuming 6.5 coaxials in the rear (havent checked yet). I did just install a JL 500/1 and a W7 10 in a JL HO box I had in the basement. It bumps pretty good, but the mids and highs dont hold up. Also, the box is HUGE. I need something smaller because my wife cant get my kids in there with the box. Also, I am using the stock HU because it has GPS and controls DVD system. Here are my questions.....
Should I just get rid of the W7 and get a new sub with a smaller box, or should I put the W7 in a smaller box? will the 500/1 be enough for a good 15" ? Any suggestions on comps for the front and an amp set up? At what point do I need to be concerned about power. I use to run a yellow top and a capacitor, but dont have those anymore. I dont seem to have a problem now, but another amp for comps , I might.
I am definitely a rookie and dont have alot of cash for this. Have to go piece by piece. Any help or suggestions would be appreciated. Thanks.
Ummm... I believe the average 15" would like a larger box.
How big is the current box? a 10" shouldn't need THAT much cubeage.
Budget for comp amp and speakers? Willing to buy used or only new?
Welcome to our humble forum //content.invisioncic.com/y282845/emoticons/wave.gif.002382ce7d7c19757ab945cc69819de1.gif
Here are the dimensions. Big for a 10" box. Id say I could spend a round 500$ or so on a mid set up. I dont mind used. Thanks for the help.
Driver(s): One 10W7-3
Continuous Power Handling: 750W
Final Impedance: 3 ohm mono
Enclosure Type: Chamber-coupled, slot-ported, rear-firing design
Finish: Dark gray carpet with red insert
Net Weight: 96.2 lbs. / 43.61 kg
(H) Height 15.25 in. / 387 mm
(W) Width 32.0 in. / 813 mm
(D1) Depth 19.25 in. / 489 mm
(D2) Top Surface Depth 14.0 in. / 356 mm
tytler32u
tytler32u
Reading PA
sacsking916
